‎2008-10-23
11:05 PM
‎2023-05-26
11:29 AM
Rubia Torres
Solved! Go to Solution.
‎2008-10-25 11:21 PM
‎2008-10-26 03:33 PM
‎2008-10-26 04:49 PM
‎2008-10-26 06:35 PM
‎2008-10-27 02:23 PM
‎2008-10-27 07:02 PM
‎2008-11-12 02:23 AM
‎2008-11-12 04:10 PM
Jooogyerek wrote:You could place all those objects in a PLN file then place it as a Hotlinked Module on a separate Story. You can also save a View to quickly access it. Any time you need any of those parts, just activate the View, and ALT-click the needed library part. I think Eric Batte's MasterTemplate uses something silimar.
I have accumulated some new questions.
1. I have set almost all the doors and windows according to my needs, but in order for the program to be able to use them they have to be present in the project, so that I can get their parameters.
Is it possible to save the individual door and window types at the same time into the main library or somewhere else, from where they can be used at any time individually or all at the same time, or create an individual library? Or I have to save all objects and tools as GSM file one-by-one?
2. If I turn on the "Arc in 2D" at arched door openings, the arc pops up just at one side. I need it on the other side too. Can it be set without GDL Script modification?I think this is not possible by default, you need to modify the script. But based on your previous success with GDL, I think you can do it.
‎2008-11-12 04:26 PM
Jooogyerek wrote:Check the attached image. You need to set the desired name in the marked fields of the DWG/DXF Translation Setup Dialog.
3. I saved a project as a DWG file. When I checked out the layers wichones were created I noticed that a layer were been created for the "Window-Door Markers". I want to rename this layer before saving as DWG.
‎2008-11-12 04:33 PM
Jooogyerek wrote:
4. When writing text it is possible to set the background fill underneath it, which (may) cover the less important lines and objects that can disturb the legibility of the text. Is it possible to set this kind of filling behind the dimension text too?
5. Since I made mass changes in the setting of the doors, more precisely with the thresholds I'm getting this error message(attached picture) during some procedures. For example, when I'm creating zones in a room in which the above mentioned door types are present as well as when I'm trying to generate the front-view. Till now it hasn't caused significant problems, but I'm curious about the cause of the problem and about the way to solve it.You have probably created a body in which two nodes are at the same position (e.g. two consecutive nodes of a SLAB or similar) so it cannot be generated in 3D. It is also possible that the dimension of some element is zero which gives similar result hen AC tries to generate its 3D.
