We value your input!
Door Textures Rotated 90 degrees
MLWheeler
Can we have a conversation about this? Seems like it's been an issue for over 10 years with no obvious answers to fix.
I am using AC25 library doors (In AC25 Solo), one pocket, one hinged -- both doors have the texture rotated 90 degrees.
Also same behaviour for architrave - texture runs perpendicular to material direction.
My room has vertical timber acoustic panelling for which I have set up custom surface, material and composites for walls; however, when I apply the surface to my doors, it displays perpendicular to the walls.
As others have said before, yes, I could setup a duplicate surface and rotate it 90 degrees, but is this really the best solution to this issue? What am I missing?
Thanks
Marcus
UKI v.25 & 26 Solo - Windows 10
20 REPLIES 20
Thanks @AllanP
Yes, the VERT/COOR commands control the texture mapping.
The problem is you need to edit the default Graphisoft Library objects to fix it.
That is not a recommended (and sometimes not easy) task to to.
