Dorr Markers rotated 90 degrees
Dave Brach
When I place an associative lable for my doors, the number is rotated 90 degrees, and I can't figure out how to correct this. Can anybody help me?
Dave Brach/architect AC28 Macbook M4 Pro OS Sequoia
4 REPLIES 4
David Maudlin
Dave:
I was able to reproduce this bug by mirroring a wall with a labeled door, using the Label Door-Marker 15. There is code in the label for Wall_Direction that I think is supposed to correct for this. The only solution I found was to change the Label Rotation value (Label Settings > Symbol Label > Rotation Angle) to 90.01Ëš (setting this to 90Ëš does not work correctly).
It would help if you named the Label you are using, as well as added screen shots of the problem.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
AC29 USA Perpetual • Mac mini M4 Pro OSX15 | 64 gb ram • MacBook Pro M3 Pro | 36 gb ram OSX14
Dave Brach
Thanks, David.
I am using Label Door-Marker14. In my case, if I change the rotation to 270.01 degrees then it is correct. So that works but it's a little annoying.
Attached is a screen shot
David Maudlin
Dave:
I found this problem in plan, doors in walls running x axis are ok, doors in walls running y axis show the bug. Besides trying to correct the GDL code in the Label, I don't see a solution.
Dave Brach
I found that if I use the eye dropper/needle to transfer properties from a window label to the door label, then it corrects the door label.
