2024 Technology Preview Program
Edit 2d-symbol of created object
Hi!
I'm trying to create my own library object based on a morph cube. It's just a very simple object that should be a displayed as a cube in 3D and elevation but in plan I want it to show as a lamp symbol.
How do I edit the symbol visible in plan?
22 REPLIES 22
You are using the parameters incorrectly.
You need to be checking for the value of the parameter.
For a boolean it is 1 or 0 (on or off).
For a text parameter you need to be using the value typed into that text parameter - in tour case "SB"
That's great, thank you for that.
ArchiCAD 19, 25 & 27
Windows 11
Lingwisyer
Guru
For the boolean, you do not actually have to put the value, you can just write "IF [parameter] then". Using this same notation, you can utilise it within sums, usually to decide whether or not to add a value.
