Edit window sash location in plan
EH21
This is for the object W Double Hung MU 27 and W Double Hung 27. All settings appear to be the same, and they look fine in 3D, but the sashes on the 2-wide unit are in the wrong position (located to the exterior). Am I missing something? How can I correct this?
Operating system used: Mac Apple Silicon 14 Sonoma
I don't seem to have those particular windows as I have the AUS library.
But the ones I do have work fine.
What language of Archicad are you using?
Are you sure that you place both windows in the same side of the wall (Exterior) with the first click?
But the 3D looks correct, so I don't think that is the problem.
Guru
Not a Complex Wall is it? Is that still a bug in 27?
Setup info provided by author
