Destilat Design
Electrical Objects
Is there a library for electrical objects that are 3D modelled and have the correct electrical symbol in the floorplan? I just want to place one object and has the right 3D display in my section and just the electrical symbol in the floorplan.
I am working with ArchiCad 26 on macOS Big Sur.
Thank you in advance.
6 Replies 6
Jere
"correct" symbol is hard to define, but Archicad's built-in objects are somewhat ok. They work decently for receptacles and switches, but I find I often still have to do 2D work like adding extra text. The GFCI symbol, range symbols, etc. don't really match the standard in my area. And it's a relatively limited set of symbols.
But the 3D portions of the objects are good (though a touch inconsistent with entering height data)
ArchiCAD 26; Windows 11; Intel i7-10700KF; 64GB RAM, GeForce GTX 3060
Javier Alvez
-translation-
Can you share?
Podrias compartir conmigo ese objeto?
Eduardo Rolon
@Javier Alvez Post have to be in English.
Those objects are part of the standard AC Library so check there.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
Leire Bilbao
Hello! Are they part of the international library or the US library?
I have the intentional and all the electrical symbols that I have don't have any 3D...
Eduardo Rolon
Did not check Int so maybe they are US only.
AC29 US/INT -> AC08
another Moderator
Botonis
Mentor
The best electrical library by far.
It was updated recently but unfortunately not translated to English yet.
I had bought the previous 1.6 version.
https://gdlfragments.com/
