Exporting and importing object parameters
Pato99
I have a range of electrical objects (+50), each time I make an addition I need to add a parameter manually. I wish there was a way to export that parameter or all parameters as an xml then import them into the next object along with it's values.
Versions 10 to forced subscription
Please vote for Constant thickness to mesh What will GS do when they reach 200 votes? Less than 30 votes to go!
Please also vote for my whishes, as 200 votes in 6 months is an impossible target, don't be a bystander:
1. Relative file locations | 2. Auto text in Publishing | 3. Model types to Grasshopper | 4. Index Numbers in Search | 5. Step through Elevations | 6. Rhino is better than ArchiCAD
Here's a reminder of what you're voting for: Wishes Delivered
David Maudlin
PatHarding88:
What you should do is create your own Subtype for your electrical objects. Parameters in this Subtype will appear in all child objects of the Subtype (in blue). If some of the parameters are not used in particle Objects, then they can be hidden and removed from parameter transfer.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
If You exported the library to xml You can of course copy the parameters section between objects...but subtype is the easiest way.
Best Regards,
Piotr
