Favorite Converter Tool - AC28
JLopes
I'm having problems with the tool to convert favorites, is there any tutorial?
Since the link in question is not directed!!!!
|| JLopes ||
AC29 Port || Ryzen 9 5900x | RTX3080 | Win
22 REPLIES 22
Hi @Patrick_lgs ,
The conversion works the same way in all language versions. Could you please provide more details about your exact issue?
Regards,
Magdolna
well,
I followed the steps on the pdf you provided
After the failure I downloaded the INT version of AC and it worked perfectly. But I can use the favorites converted because then I have a mix of ING and POR language.
HI Magdolna - is the video tutorial ready?
@Magdolna Marosvari wrote:
The screenshot @JLopes showed is already about the user friendly version, that can be downloaded from here:
https://graphisoft.com/resources-and-support/downloads?section=favorite-converter
I'll update the link, also the FAQ, and the tutorial video can be expected around 17th October
@Magdolna Marosvari
Does this apply to the Mapping Value Table as well with regards to the video?
https://graphisoft.com/resources-and-support/downloads?section=mapping-value-table&localization=AUS
There is a link but currently it does not work.
Hi @Barry Kelly ,
Thank you for letting us know about the warning, it'll be fixed soon.
Meanwhile you can find the Mapping Value explanation video attached.
The library package developer documentation is on its way too, it can be expected in the upcoming weeks.
Best regards,
Magdolna
Hi @Natalie Adams ,
The Favorit Converter video is a bit late, it can be expected in the upcoming weeks.
In the meantime you can use this documentation to see how it works. It has lot of screenshots to make sure that the workflow is clear. The video will show the same just in video format.
Best regards,
Magdolna
Hi @Patrick_lgs ,
Thank you for the further info. To have a clean start, may I ask you to delete the files and folders you show, then extract the ZIP file again to a different location, and from there manually add the add-on in to the add-on manager? We could reproduce this error by deleting the libpart_pairs.csv from the favorite_converter_data folder, so probably your file arrangement got mixed up during multiple tries.
And indeed the result of the converter is independent of the language version of Archicad, so you can use the ones generated by INT. Because it doesn't use data coming from Archicad, only data from the folders and files next to the add-on.
Regards,
Magdolna
Yeah, agree with you on this and am not sure if the converter really does work? Does it also have any difference migrating an Archicad 27 project over to Archicad 28 and then from there you export the favorites, seems to work since am rebuilding it also... Any thoughts on this? Thanks!
WINDOWS 11 PRO
Setup info provided by author
