GDL - Cylind & Elbow Contour Lines
Is it possible to get rid of the contour lines between the Cylinders and Elbow? or can you only control visible lines with PRISM_ ect.?
Is there a better way to do this?
11 REPLIES 11
Frank Beister
Cylind and elbow do not have parameters for that. Try this one. I think it can do: Knee
I think if you use Grouping to add them together you can.
Otherwise use Prism for the straight parts and Revolves for the curved parts.
Yes Grouping does it.
Try this.
GROUP "one"
CYLIND 0.05, 0.025
ENDGROUP
GROUP "two"
ADDz 0.05
CYLIND 0.05, 0.025
ENDGROUP
result = ADDGROUP ("one", "two")
PLACEGROUP result
Barry
Perfect!
Thanks Barry.
Actually doesn't seem to work if you group a cylinder and an elbow. works with two cylinders though.
Dwight
There's always Trussmaker.
Dwight Atkinson
Frank Beister
a=1 : b=0.2
k=0
s=0
n=36
winkel=30
rsl=24
hotspot 0,0,htspt
for i=0 to n
  put b*cos(360/n*i)
  put a+b*sin(360/n*i)
  put 1
  next i
if rsl>3 then resol rsl
revolve n+1, winkel, 1*0+2+4+8+16*s+32*s+64*k,
   get(nsp)
Are you sure?
a=1 : b=0.2
k=0
s=0
n=36
winkel=60
rsl=24
GROUP "one"
CYLIND 0.2, 0.2
ENDGROUP
GROUP "two"
ADD 0,-a,0.2
hotspot 0,0,htspt
for i=0 to n
put b*cos(360/n*i)
put 1
next i
revolve n+1, winkel, 1*0+2+4+8+16*s+32*1+64*k,
get(nsp)
ENDGROUP
result = ADDGROUP ( "one", "two")
PLACEGROUP result
You can control the lines at the ends of the revolve with the masking values (ie 16 & 32) as Frank was demonstrating.
Yeah definately didn't work with Cylind & Elbow unless there is something im missing.
Will try with revolve. Thanks
