GDL-Object always looking to camera
I want my (Bitmap)GDL-object always to look into the camera. I know I can Use GLOB_EYEPOS_X or _Y or _Z. But how do I do that? I don't find it in the manual...
thanks a lot
Macangelo
7 Replies 7
Frank Beister
I don't have the code by the hand, but you should find it in the gdl cookbook or by search in this forum.
... und im Übrigen bin ich der Meinung, dass Trockenbauwände einschichtig zu modellieren sind.
thanks a lot
Macangelo
Macangelo,
Here's part of one of my scripts that rotate. I developed it so long ago, I don't really remember how to explain it...I think I go the concept from DNC.
anyway, here it is:
dkx=K~-X~:if dkx=0 then dkx=1
dly=L~-Y~:if dly=0 then dly=1
dazi=ATN(dly/dkx)
if (dazi+90) >90 then rotz 180
if (dazi+90) <90 then rotz 0
HTH,
dan K
Hi Dan,
Thanks for your try.
I copied and pasted your code and get the error message:
"Die Verwendung von realen Typen kann zu Präzisionsproblemen führen." meaning something like "The usage of real types can lead to precision problems." or something 😉
I replaced K~ with GLOB_EYEPOS_X and L~ with GLOB_EYEPOS_Y - same result.
And it does not turn my object.
Any ideas?
Thanks a lot and have wonderful day
Macangelo
macangelo wrote:
Hi Dan,
...Macangelo
You can ignore the "The usage of real types can lead to precision problems" message.
Sometimes you need to rebuild the window for the object to turn.
The older K~ and L~ global variables should still work. If you still cant get it to work post your full 3d script here for us to see and comment.
Dan K
Macangelo,
Try this ... I know it works... just remember that you will probably need to do a "rebuild and regenerate" to see the rotation.
P.S. note that it even works correctly if the symbol is mirrored!
2d Script:
project2 2,270,1
3d Script:
dazi=ATN(dly/dkx)
if SYMB_MIRRORED goto 20
rotz 90+dazi-W~
goto 30
20:
rotz -90-dazi+W~
30:
ADDX -A/2
block a,1',1'
Hi Dan,
thanks for the offer. Here's my full code. I try your new code as soon as I'm back at my desk.
Best
Macangelo
SHADOW on
dkx=GLOB_EYEPOS_X-X~:if dkx=0 then dkx=1
dly=GLOB_EYEPOS_Y-Y~:if dly=0 then dly=1
dazi=ATN(dly/dkx)
rotx 90
B=199*ZZYZX/480
ADDX -B/2
PICTURE "PEOPLE10.TIF", B, ZZYZX, 1
Hi Dan,
Many, many thanks - it works!
Have a wonderful day
Macangelo
