GDL-Object always looking to camera
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2006-05-25 09:05 AM
2006-05-25
09:05 AM
I want my (Bitmap)GDL-object always to look into the camera. I know I can Use GLOB_EYEPOS_X or _Y or _Z. But how do I do that? I don't find it in the manual...
thanks a lot
Macangelo
7 REPLIES 7
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2006-05-25 11:04 AM
2006-05-25
11:04 AM
I don't have the code by the hand, but you should find it in the gdl cookbook or by search in this forum.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2006-05-25 06:24 PM
2006-05-25
06:24 PM
macangelo wrote:Macangelo,
thanks a lot
Macangelo
Here's part of one of my scripts that rotate. I developed it so long ago, I don't really remember how to explain it...I think I go the concept from DNC.
anyway, here it is:
dkx=K~-X~:if dkx=0 then dkx=1
dly=L~-Y~:if dly=0 then dly=1
dazi=ATN(dly/dkx)
if (dazi+90) >90 then rotz 180
if (dazi+90) <90 then rotz 0
HTH,
dan K
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2006-05-25 08:00 PM
2006-05-25
08:00 PM
Hi Dan,
Thanks for your try.
I copied and pasted your code and get the error message:
"Die Verwendung von realen Typen kann zu Präzisionsproblemen führen." meaning something like "The usage of real types can lead to precision problems." or something😉
I replaced K~ with GLOB_EYEPOS_X and L~ with GLOB_EYEPOS_Y - same result.
And it does not turn my object.
Any ideas?
Thanks a lot and have wonderful day
Macangelo
Any ideas?
Macangelo
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2006-05-25 08:33 PM
2006-05-25
08:33 PM
macangelo wrote:You can ignore the "The usage of real types can lead to precision problems" message.
Hi Dan,
...Macangelo
Sometimes you need to rebuild the window for the object to turn.
The older K~ and L~ global variables should still work. If you still cant get it to work post your full 3d script here for us to see and comment.
Dan K
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2006-05-25 08:56 PM
2006-05-25
08:56 PM
Macangelo,
Try this ... I know it works... just remember that you will probably need to do a "rebuild and regenerate" to see the rotation.
P.S. note that it even works correctly if the symbol is mirrored!
2d Script:
project2 2,270,1
3d Script:
dazi=ATN(dly/dkx)
if SYMB_MIRRORED goto 20
rotz 90+dazi-W~
goto 30
20:
rotz -90-dazi+W~
30:
ADDX -A/2
block a,1',1'
2d Script:
project2 2,270,1
3d Script:
dazi=ATN(dly/dkx)
rotz 90+dazi-W~
goto 30
20:
rotz -90-dazi+W~
30:
ADDX -A/2
block a,1',1'
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2006-05-25 09:19 PM
2006-05-25
09:19 PM
Hi Dan,
thanks for the offer. Here's my full code. I try your new code as soon as I'm back at my desk.
Best
Macangelo
SHADOW on
dkx=GLOB_EYEPOS_X-X~:if dkx=0 then dkx=1
dly=GLOB_EYEPOS_Y-Y~:if dly=0 then dly=1
dazi=ATN(dly/dkx)
rotx 90
B=199*ZZYZX/480
ADDX -B/2
PICTURE "PEOPLE10.TIF", B, ZZYZX, 1
Best
Macangelo
SHADOW on
dazi=ATN(dly/dkx)
rotx 90
B=199*ZZYZX/480
ADDX -B/2
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2006-05-26 09:40 AM
2006-05-26
09:40 AM
Hi Dan,
Many, many thanks - it works!
Have a wonderful day
Macangelo
Macangelo
