GDL XML Extension
Can anybody help me with the GDL XML Extension? I'm trying to decode it since 4 days and i have no idea how it works! The ArchiCAD 9 documentation is very confusing or i'm so stupid
I'm trying to teach my GDL how to output data like dimensions and price in a XML file so i can read it with an JAVA script. My Problem i have no idea how the GDL XML syntax works!
The best for me would be to download a GDL objekt where this GDL XML Extension script is use so i can whatch how to write it!
11 REPLIES 11
Again my question: Are you familiar with the XML format? Do you have an aim of export format/structure? Can you create such an file "by hand" and post it?
Not exactly me but a Teammate is very good in those things. He makes our websites and other things with HTML/PHP/JAVA/XML. My part of this project is to "learn" to write the GDL object an he makes the JAVA programm to read the hole data.
I also think that i have to tell him a node but how? I can define a node with an Number (like 00 or 01) or with a Name. The two things are possible but in the GDL Documentation is nothing explained how to use this command.
Cosminn
Hello to all.
I need an add on to open, read and modify a document "xml", or have to write a script into a new object.
Sincerely,
Daniel
