GDL objects with adjustable materials
How do I create a GDL object where I can adjust the materials individually? The only way I know how to do it doesn't save the individual materials, and the only way to change material is to un-tic the "Use Object's Materials" box and choose a different material, but this changes the entire object.
Your help welcomed! Thanks!
12 Replies 12
Check the GDL Reference Guide:
You have to have a file called MASTER_GDLxxxxxxxxx.gdl
In the place of xxxxxxxxx you can put any characters so the name of the file will be e.g. MASTER_GDL-OfficeMaterials.gdl
This file must be loaded in the loaded libraries.
You can edit this file in Notepad, it is a text file, with the GDL extension.
In this file you can use any of the DEFINE commands of GDL to define fills, materials, line types, textures etc.
These DEFINE commands are covered in the GDL Manual PDF on pages 196-212
Their result is when you reload libraries and a library contains a MASTER_GDL... file, the content of the file is executed, and if there are those DEFINE commands, the attributes defined in the MASTER_GDL file will be added to the attribute set of the project.
Thank you very mutch laszlonagy and all the other people who replayed.
I am very new to GDL so this is very helpful. If its possible, can you post a example? It is a little bit easy for me to understand now in the beggining.
Thank you very mutch.
The examples are there in the GDL Reference Guide PDF.
I copied one example:
DEFINE MATERIAL "water" 0,
0.5284, 0.5989, 0.6167,
! surface RGB [0.0..1.0]
1.0, 0.5, 0.5, 0.9,
! ambient, diffuse, specular,transparent
! coefficients [0.0..1.0]
2.0,
! shining [0.0..100.0]
1,
! transparency attenuation [0.0..4.0]
! specular RGB [0.0..1.0]
0, 0, 0,
! emission RGB [0.0..1.0]
0.0
! emission attenuation [0.0..65.5]
Note that the lines starting with ! are comments.
So the real script is:
1.0, 0.5, 0.5, 0.9,
2.0,
1,
0, 0, 0,
0.0
So if you paste this into Notepad, save it as MASTER_GDL-1.gdl for example, then place this file into any of your loaded libraries, reload the libraries, the new material will be there among your materials.
