Groups & SOE within Loops
Hi there,
I am creating a pile layout & want the piles to cut away the footings.
I can do this easily within the script using groups, & a operation but it doesnt work within the loop:
The Solid Operation works fine on the first pile but none of the others show up. Do I need to put the group/ Subgroup elsewhere?
ie:
FOR k = 0 TO A STEP pileCentres
ADDX k
GOSUB 100:
NEXT k
END
100: ! Piles
GROUP 'Pile' !!!!Group for Solid operation
BLOCK pileSize, pileSize, pileFootingDeptht
ENDGROUP
GROUP 'Footing'
BLOCK footingSize, footingSize, footingDepth
ENDGROUP
subtractedFooting = SUBGROUP('Footing', 'Pile')
finished = SUBGROUP(subtractedFooting, 'Pile')
PLACEGROUP finished
KILLGROUP 'Footing'
KILLGROUP 'Pile'
KILLGROUP finished
RETURN
Please Help!! thanks!!
2 REPLIES 2
rocorona
Group names can't be reused in the same script. not even if previously killed.
This one works for me:
DIM subtractedFooting []
DIM finished[]
ENDGROUP
GROUP 'Footing'
ENDGROUP
ADDX k
GOSUB 100:
NEXT k
KILLGROUP 'Footing'
KILLGROUP 'Pile'
END
100: ! Piles
subtractedFooting[k+1] = SUBGROUP('Footing', 'Pile')
finished[k+1] = SUBGROUP(subtractedFooting[k+1], 'Pile')
PLACEGROUP finished [k+1]
KILLGROUP finished [k+1]
RETURN
But, if elements are all the same, why not simply repeat the placement?
i.e., after defining the groups:
PLACEGROUP finished
ADDx k
NEXT k
_________________
--Roberto Corona--
www.archiradar.com
AC18 - ITA full on Win10
_________________
_________________
Hello Roberto
Thank you very much for your advice & help,
after a bit of playing around I got the second method to work!!
I dont think the code is 100% efficient right nowm, but its working & i will fine tune.
thanks again!
