Guide me to create CHAIR
Hello Everyone,
Can anyone help me in guiding how can the complex chair can be created. I am trying it using tube command.
Following are the parameters...
Parameters:
• A / B / total Z size
• Seat height
• Material chair
Though i am making one object which is under progress and i am attaching the back of that chair is not adjusted in align which inclined legs.
Thanks in advance.
Regards
Deepak Malhotra
6 REPLIES 6
Djordje
Deepak,
Try to find somewhere a copy of GDL Cookbook ... it will help you no end! I know that there are quite a few copies in India, but that does not mean a lot, I know ...
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Thomas Holm
Djordje
Thomas wrote:
http://www.nottingham.ac.uk/sbe/cookbook/gdl_cookbook/index.html
http://www.nottingham.ac.uk/sbe/cookbook/CB4_Web/
Great memory, Thomas!
And the Tubes are at http://www.nottingham.ac.uk/sbe/cookbook/CB4_Web/tubes01/Tubes01.html
One piece of advice for Deepak: stick to the DNC rule of having the origin go back to 0,0,0 after you finish and assembly. Also, make sure that you title your parts in the script. This will enable you to revise and enhance the object, if you wish or need to.
Good luck!
Djordje
HP Omen
Sir,
Nice peice of advice and material. Thanks a lot.
Regards
Deepak
Thomas Holm
Thanks!
I think the cookbook 3.99 has an efficient interface. Problem is that I don't know how complete it is, that is if it really contains all the Cookbook 3 material or if something is missing along with what DNC planned to have on version 4.
You might still be able to get the version 3 PDF by following his instructions on this page:
Erich
If you exit the 3.99 online version and follow the links you will get to this link
http://www.nottingham.ac.uk/sbe/cookbook/CB_download/cookbook3download.html
for a PDF version of the Cookbook 3
BTW thanks a lot David! This is a real help
Erich
AC 19 6006 & AC 20
Mac OS 10.11.5
15" Retina MacBook Pro 2.6
27" iMac Retina 5K
