rob2218
Hopper styled doors? Modular Joinery? Cabinet
see attached.
i>u
Edgewater, FL!
SOFTWARE VERSION:
Archicad 22, Archicad 23
Windows7 -OS, MAC Maverick OS
10 Replies 10
Erich
What cabinets are you using?
Erich
AC 19 6006 & AC 20
Mac OS 10.11.5
15" Retina MacBook Pro 2.6
27" iMac Retina 5K
rob2218
had to use a combo of yours in some areas, pantry and kitchen and then had to find a "modular" object that was a cabinet-type object but had to have "slider" doors.
Also..was looking for a "hopper-type" door for an upper cabinet as well.........don't tell me your SUPERCABS have the hopper doors!
i>u
Edgewater, FL!
SOFTWARE VERSION:
rob2218
by the way.....your logo? follow the white rabbit? is that your favorite movie......too?
The Matrix....it's mine thats for sure.
i>u
Edgewater, FL!
SOFTWARE VERSION:
Steve Jepson
Steve Jepson
too easy
Steve Jepson
You should be able to configure these into what you want.
You may want to make a custom panel with a nob?
rob2218
yes...that is what I need.
interesting how you got the hopper windows to be opened to different angles....
i>u
Edgewater, FL!
SOFTWARE VERSION:
Steve Jepson
They are each different window.
Make a 3/4" wide wall to serve as the face frame. Add the windows ( turn off the transom feature and configure the frame and sash)
The cool thing about the cabinet placed behind the wall is that you just assign it the number of shelves you need and adjust it to the same height as the windows. If you don't need the wall/face frame, you can adjust it's length so it wont show up (windows will still be there), SEO or what ever.
I use this combo of window/bookcase/wall for face frame for lots of custom cabinet projects. I like the way they are adjustable in 3D window vs trying to configure it all in a single object that might do the same thing if you fussed with it long enough.
rob2218
Ahh...I see.
You are using AC18.....does AC17 have that same "Hopper Styled" window?
i>u
Edgewater, FL!
SOFTWARE VERSION:
