Funfun Yan
How can I import object models in the *.glb file format into Archicad?
A friend sent me some AI-generated 3D furniture models in the *.glb format. How can I use them in Archicad? Thank you!
Operating system used: Windows 6010
12 Replies 12
Erwin Edel
If you are a little bit familiar with GDL, it is very easy to add a simple and detailed toggle parameter where you could substitute the detailed model with something less detailed and swap in the detailed model for artist impressions only.
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
cuba
There is no direct import of .glb into archicad.
Convert it into .3ds file with something like https://fabconvert.com/convert/glb (add-on goodies 3dstudio in: https://www.graphisoft.com/us/downloads/goodies)
Apple M1 Max 32 GB
Latest AC
You could check if the FBX files was properly exported from Blender. There are a lot of free online FBX Viewers on the net. You could try viewing the FBX file in them:
  • If they have textures, it means that FBX export from Blender was fine, and the problem is indeed with Archicad's FBX import.
  • However, if they do not have textures even in the online FBX viewer, it probably means that FBX export from Blender was incorrect.
