Nader Belal
Mentor
How to Limit Materials in GDL
Hi there,
I was trying to limit the surfaces assigned to my object, by creating a material parameter in the parameter tab
So I tried to used "values" and "values{2}" GDL orders in the parameter script.
The Problem:
Values: only accept numerical values, which in this case it will be the surfaces' index numbers --- but surfaces' index number may have a different number each time it will be loaded to another computer.
Values{2}: I tried to assign a number and a description but couldn't
Is there a way to limit all the surface material in a material parameter so that any user can only see those selected materials ???
0 Replies 0
