2009-10-29 06:21 AM
2009-10-29 10:59 AM
martini-girl wrote:
Thank you olivier.
But can you explain how to load a Library Part as I have never done that before.
Thank you!
2009-10-29 11:17 AM
2009-10-29 11:45 AM
martini-girl wrote:MultiText - 3D Straight
Thanks Olivier. I downloaded that lbrary part woth your instructions but sadly it still doesn't give me vertical text. Only curved and multilines (which will be good later on!).
Any other suggestions?
2009-10-29 12:01 PM
2010-12-13 08:44 AM
2010-12-13 03:35 PM
wstgermaine wrote:This sounds like a task for SEOs but if you made the mesh in AutoCAD it may be difficult to get it into ArchiCAD as a viable solid. I can't recall if I've tried any solid ops with DWG parts.
I have a similar question but involving a surface that I would like to be vertical. I created a mesh in autocad and want to place it on a surface that I can cut voids out of and be vertical at the same time. I did a similar thing to a roof surface and it worked great but it can not go completely vertical. Please help if you can offer me advice.
2018-05-15 10:12 AM
2018-05-15 10:35 AM
anadoramateiL53 wrote:I found a link to it in another post, but that web page doesn't exist any more.
Is there a particular way I can download the library for the 3D MultiText? It seems I can only open the png...
Thank you,
Ana
2018-05-15 10:46 AM
AC22-23 AUS 7000 | Help Those Help You - Add a Signature |
Win11 | i9 10850K | 64GB | RX6600 | Win10 | R5 2600 | 16GB | GTX1660 |
2018-05-21 08:43 AM
