How to inspect generated code?
Hi
I'm using the SWEEP command. I generate a slab in the floorplan that I drag toe GDL-editor. And that gives me a lot of coordinates for the curve in the plan. I also make a polyline in the space and put the scale to 1.1.
But, the problem is: I would like to have the coordinates for the curve that is generated at last.(The top of the figure), because I would like to use the MASS command and create a figure on top of this. The last generated coordinates in the first figure is the ground line in the second figure.
See what I mean? So how do I inspect the generated coordinates?
6 REPLIES 6
David Maudlin
Anne:
No figures are attached, very hard to understand the issue without them.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Here is the picture of the back of the chair, so far, and a picture of the chair I'm trying to make.
Erich
Anne,
You might want to take a look at the COONS command rather than MASS to make this one. This command allows you to define two pairs of space curves and then interpolates a surface between them. Without checking, I don't have archicad at hand right now, I don't recall if you can get the top and bottom surfaces to generate so you might need to add those separately.
HTH
Erich
AC 19 6006 & AC 20
Mac OS 10.11.5
15" Retina MacBook Pro 2.6
27" iMac Retina 5K
I would suggest RULED, which behaves like Erich described.
Two curves, a base and a space one.
This could be made with COONS too, but is a more
laborious way having 4 edge curves for each surface.
Hope this helps.
Erich
Another option could be to use the sweep command. The scaling factor in this command could allow for the flair of the back of the chair.
Erich
AC 19 6006 & AC 20
Mac OS 10.11.5
27" iMac Retina 5K
Frank Beister
material_decke=SYMB_MAT
material_boden=SYMB_MAT
material_seite=SYMB_MAT
material_neigung=SYMB_MAT
c = 0.04 / 2   ! half thickness
d = 0.1         ! offset each side
msk=8+2+64
rotx 90
for i=-1 to 1 step 2
  mulz i
  HPRISM_ material_decke, material_boden, material_seite, material_neigung,
    4, c, 0, c, 1,
    d,0,msk,
	a-d,0,msk,
	a,zzyzx,msk,
	0,zzyzx,msk
  del 1
  next i
del 1
Not curved, but done in 5 minutes. šŸ˜‰
