2015-11-10 10:39 AM
2015-11-10 07:59 PM
SenecaDesignLLC wrote:Very good. We used different method.mariosmic wrote:I am also only using 4+256 on curved tubes, I use box method for the tube when its straightSenecaDesignLLC wrote:I tried 4+256 with tube. It doesn't work to me. Where did you find this 256 mask?
I got it to work with the tube and 4+256
2016-01-07 09:40 AM
2016-01-07 10:29 AM
SenecaDesignLLC wrote:Very good work. Are you still using objects cutted or other method?
figured it out. got the same out come with my railing tool using tube as your pathway
2016-01-07 02:50 PM
mariosmic wrote:I am using the tube command with a custom profile from a polyline.SenecaDesignLLC wrote:Very good work. Are you still using objects cutted or other method?
2016-01-08 09:44 AM
SenecaDesignLLC wrote:which primitive did you use in GDL?mariosmic wrote:I am using the tube command with a custom profile from a polyline.SenecaDesignLLC wrote:Very good work. Are you still using objects cutted or other method?
2016-01-09 09:40 AM
2016-01-09 10:12 AM
Pertti wrote:ok
If you split the tube into segments instead of tubing you can address coor command to every segment individually.
2016-01-09 05:40 PM
mariosmic wrote:exactly i used 2+1024 for the coor. took me a minute to calculate the positions to have the material line up. I am still a little off with the rise.Pertti wrote:ok
2016-01-09 05:44 PM
2016-01-09 05:49 PM
