How to map a circular material
Does any have any pointers for curved material mapping? Say on a tube curving for railing
20 REPLIES 20
Mario Sacco
SenecaDesignLLC wrote:
I got it to work with the tube and 4+256
I tried 4+256 with tube. It doesn't work to me. Where did you find this 256 mask?
I am also only using 4+256 on curved tubes, I use box method for the tube when its straight
Very good. We used different method.
MacBook M1 Max 64GB- OS X 12.2.1 - Archicad 27
https://www.archiradar.it/en/
figured it out. got the same out come with my railing tool using tube as your pathway
Mario Sacco
Very good work. Are you still using objects cutted or other method?
I am using the tube command with a custom profile from a polyline.
Mario Sacco
which primitive did you use in GDL?
Pertti Paasky
If you split the tube into segments instead of tubing you can address coor command to every segment individually.
- AC-24 FIN - WIN 10 - HP Zbook -
“A winner is just a loser who tried one more time.”
George M. Moore, Jr.
Mario Sacco
ok
mariosmic wrote:
ok
exactly i used 2+1024 for the coor. took me a minute to calculate the positions to have the material line up. I am still a little off with the rise.
but depending on the material and resolution it still does pretty good.
wood grain with high resolution
