I need an odd sized door for ArchiCAD 9. SOMEONE HELP!
I NEED AN 112 3/4" x 80" SIZED DOOR. ITS A TRIPLE FRENCH WITH THE DOOR EITHER ON THE LEFT OR RIGHT, NOT THE CENTER. THE OTHER TWO DOORS ARE STATIONARY. SOMEONE PLEASE HELP ME. THANK YOU FOR YOUR TIME.
11 Replies 11
I CANT GET MY PIC TO WORK
Tom wrote:
Really? Maybe the US standard library is different.
No it's not... sort of. That option IS available in the US versions also in the "AC9 Library Special Edition", but I didn't find it in the "AC9 lib for SE9". The first one is the library with the graphic display of the stacking/ganging option. The second one would've or should've had the option within the parameters, but doesn't, and I'm pretty sure I have the latest libraries.
I've been told that both should be loaded, but just about the time I was about to remove the "AC9 lib for SE9" library, version 10 came out and I haven't bothered much with these libraries.
