2022-05-03
02:01 AM
2025-01-02
03:19 PM
Molinda Prey
It understands that when I move elements, the label follows them.
But, shouldn't the label follow when it is stretched?
I want to move only the objects except the label.
2022-05-03 03:56 AM - edited 2022-05-03 05:45 AM
Because you are stretching the entire elements, you are effectively moving them, hence the labels will move as well.
I am not sure of a way around this.
Not even locking the label will make it stay put.
2022-05-03 04:29 AM
Thank you
there's no way
2022-05-06 01:02 AM
What I would do in such a case is I would remember the exact angle and distance that I moved my elements, then I would select the moved Labels and moved them back to their original place by the same distance in the opposite direction (angle).
