We value your input!
I want to move only the objects except the label.
LeeJaeYoung
It understands that when I move elements, the label follows them.
But, shouldn't the label follow when it is stretched?
AC27 on window 11
Because you are stretching the entire elements, you are effectively moving them, hence the labels will move as well.
I am not sure of a way around this.
Not even locking the label will make it stay put.
Thank you
there's no way
AC27 on window 11
What I would do in such a case is I would remember the exact angle and distance that I moved my elements, then I would select the moved Labels and moved them back to their original place by the same distance in the opposite direction (angle).
