Importing Archicad 10 Libary into Archicad 13 Libary
Hi all, can someone please explain to me how to import my archicad 10 libary into my archicad 13, because there is not all the textures and wall sizes etc in 13 as there was in 10
5 REPLIES 5
David Larrew
Have you tried reviewing the "Migration Guide" located in the ArchiCAD Help? There is a section that explains Library handling.
David Larrew, AIA, GDLA, GSRC
a r c h i S O L U T I O N S
WIN7-10/ OSX 10.15.7
AC 5.1-25 USA
yes i did look thru the migration guide, but was very confusing, so can any one direct me to somewhere that can clearly explain what to do????
Erika Epstein
with AC open , under the help menu, go to downloads. There find the AC10 migration library. This can be loaded in conjunction with the AC13 library.
Also you can always open a 10 file with only the AC10 library loaded. You do not have to use the AC13 library.
HTH
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
Hi Erika, thanks for your suggestion, it worked, my other question is how can i get the materials and cut fills for walls from AC10 onto AC13, as 13 does not have as much choice as 10, besides opening a archicad 10 file in 13 which i have been able to do?
If you want to transfer all the attributes (like materials, fill types etc.), then you should use the Attribute Manager.
Open the AC10 Template file and transfer attributes you need.
