2010-07-03 09:24 PM
n=REQUEST ("Name_of_material", index, name)
I tried this, and can see that variable n is 0 when there is no material with that index, while it is 1 when a material exists. 2010-07-07 01:06 AM
!--define arrays
dim s[], t[]
!--loop thru materials
for xx=1 to 255
dummy= REQUEST ("Name_of_material", xx, name)
if dummy & (strsub(materials,1,1) = strsub(name,1,1)) then
n= n+1
t= name
endif
next xx
!--array sorting
for i=1 to vardim1(t)
s= ""
next i
p=i
for j=1 to i-1
if s>t then
for k=i to j+1 step -1
s=s[k-1]
next k
p=j : j=vardim1(s)
endif
next j
s=t
next i
!--deliver the value list
values "materials" s, custom
2010-07-07 01:20 AM
!--define arrays
dim s[], t[]
for xx=1 to 255
if dummy & strstr(name, materials) then
n= n+1
t= name
endif
next xx
!--array sorting
s= ""
next i
p=i
for j=1 to i-1
if s>t then
s=s[k-1]
next k
p=j : j=vardim1(s)
endif
next j
s=t
next i
2010-07-07 01:32 AM
is executed, and you have a similar statement in your script as you loop through to collect the material names. Do you get error messages when your script is executed?2010-07-07 07:10 AM
!--define arrays
dim s[], t[]
for xx=1 to 255
test= REQUEST{2}("Material_info", xx, "gs_mat_surface_rgb", r, g, b)
if test then
dummy= REQUEST("Name_of_material", xx, name)
if strsub(materials,1,1) = strsub(name,1,1) then
n= n+1
t= name
endif
endif
next xx
!--array sorting
s= "" !--for numbers-->0 | for strings-->""
next i
p=i
for j=1 to i-1
if s>t then
s=s[k-1]
next k
p=j : j=vardim1(s)
endif
next j
s=t
next i
2010-07-07 08:40 AM
project2{2} 3,270,3+1024
This is crude, but gives a quick preview of the squares with a simple color based on the material, but it does not use the actual texture files of the materials.n=REQUEST{2} ("Material_info", "07 | Spanish Tile", "gs_mat_texture", file_name, w, h, mask, alpha)
DEFINE IMAGE_FILL "TestFill" file_name, fillTYPES_MASK 2, 85, 255, 136, 255, 34, 255, 136, 255, h, w, 0, 0
However, when I use the Check Script button, I get a syntax error for the second line that says "String type expression required at line 7..." I don't know what my error is - can you try this and let me know what I'm doing wrong? 2010-07-07 09:56 AM
2010-07-08 02:21 PM
Eric wrote:Hi Eric,
... when I use the Check Script button [with DEFINE IMAGE_FILL], I get a syntax error for the second line that says "String type expression required at line 7..." I don't know what my error is - can you try this and let me know what I'm doing wrong?
2010-07-08 04:54 PM
2010-07-08 09:52 PM
n=REQUEST{2} ("Material_info", "Testing Material", "gs_mat_texture", file_name, w, h, mask, alpha)
parameters pict[1]= file_name
DEFINE IMAGE_FILL "Testing" pict[1], 255, 255, 255, 255, 255, 255, 255, 255, w, h, 0, 0
set IMAGE_FILL "Testing"
poly2_ 4, 1+2+4+8,
0, 0, 0,
a, 0, 0,
a, b, 0,
0, b, 0
