We value your input!
LIFT
Can anybody tell me why the download button for this object https://bimcomponents.com/GSM/Details/18354# remains inactive?
I can not download it.
7 REPLIES 7
Works fine for me when I drag it into Archicad.
Barry,how can i drag it to my archicad without downloading it?
That big curvy arrow button isn't a download button - it is a drag into Archicad button.
Click it and drag it onto the Archicad icon at the bottom of your screen (Archicad must be running of course) and wait for Archicad to open, then continue dragging onto the floor plan window.
Or you can go into the object settings and browse for "Lift" or whatever key word you want to use and wait for the BIMComponent object to show in the list.
Then you will have a download button.
Thought I had better try this.
Works fine both ways in Archicad 18.
Comes up with a "Serious error during download" message when I try either method in version 19.
Thanks Barry now it works.When i open the object all parameters come with a ? mark.Is it because i'm on Mac or is it because i opened it in AC17? Can i edit the object? say remove one cabin and have only one?
Thank you for your help.
It appears this was written for another language.
When I open the object to edit the script you can see their proper names.
As we don't have the required font/language installed all we see is ???
Looking at the script there are no options to adjust anything - only material and pen parameters.
You could possibly convert it to a Morph and edit it from there but it might get messy.
Thank you Barry for your help,you 've been very helpful.
David Maudlin
I ran into this error message yesterday, but discovered the object in the Embedded Library anyway. I got normal results using an earlier version of AC.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
