Library Objects not showing in 3D - Library not Missing
marianadesm
Hi there!
We are in need of some help with a problem related with a specific machine and a project. It's a teamwork project and all other users can see everything correctly.
There is a specific member who cannot see some windows, from a specific library downloaded from bimobject (Wicona Library). (IMG_1)
Important facts and notes we already checked:
- the library is loaded in the project and is not missing; (IMG_2)
- We tried both with a local library and the BIMCloud Library and in both cases, it doesn't show up; (IMG_3)
- The objects appear in floor plans and sections, they just don't show up in 3D;
- If this specific user opens his account in other computer and enters the teamwork project, the objects will display correctly;
- If this specific user/machine opens a .pln version of the project, that's not in the BimCloud, the problem still exists and the 3D objects are not displayed;
Everything makes me think that is something related to the archicad/computer and has nothing to do with the BIMCloud or this specific user.
Any idead what it can be? I already found a similar/related article - https://community.graphisoft.com/t5/Teamwork-BIMcloud/Library-objects-not-showing-without-library-be... - But it's from archicad 24 and in that case it appeared the black dots, which is something that doesn't happen here.
Hoping you can help! Thank you!
Operating system used: Windows 11 Pro 22H2
Mariana Magalhães
Graphisoft Certified Archicad BIM Coordinator & BIM Manager
marianadesm
Hi everyone! So, the problem was solved by cleaning preferences, following the steps that are exposed in the next article:
https://community.graphisoft.com/t5/Installation-update/Preferences-Cleaning/ta-p/303676
Thank you!
Mariana Magalhães
CosminF
I would check the Model View Options, maybe it somehow adds an exclusion from the 3D display of the element. And maybe the setting is made just on one machine.
Cosmin Furdui - architect @ Wincon
AC 27, running on Windows 11 Intel(R) Core(TM) i7-14700K CPU64, 3.40GHz, 32GB RAM, Nvidia GeForce RTX5060 32GB
marianadesm
Thank you!
Mariana Magalhães
Setup info provided by author
