Library Part Maker template 29
Xavi
Hi
I can not find the Template for the Library Part Maker.
I did Install everything but when I try to find the template is not there.
Many Thanks
10 REPLIES 10
Have you loaded the 'Library Part Maker' library pack?
This needs to be loaded in addition to the other library packs.
Xavi
Hello Barry
Where I can find the  'Library Part Maker' library pack?
Thanks
Once you have installed the add-on. the library pack should be in the Archicad Program folder with all of the other library packs.
Thanks Barry, I did found.
But where I can find the template?
By template, do you mean the palette?
Help can be found here...
https://help.graphisoft.com/AC/29/INT/index.htm?rhcsh=1&rhnewwnd=0&rhmapid=#t=_AC29_Help%2F046_Libra...
Xavi
By Template I mean Template. Like this one on the screenshot.
Is a german version, but ddi also exist a international.
This Template comes with Window and door example.
I wasn't aware that there is a template.
I understand that you add your own design area and components.
But I am not a user of LPM.
I see at least some of the samples in your template image are the same ones shown in the help file that I linked to.
I haven't read through it all so am not sure if there is a link to a sample file in there.
I didn't see one after having a quick look.
There must be a file somewhere if those examples are the same.
I just don't know where.
Anyone else have an idea?
Erwin Edel
I've not seen this as part of the Dutch version, but something similar has been provided by our reseller in the shape of .MOD files in a separate folder within the AC installation folder.
Templates would be in the 'defaults' folder in your AC installation folder.
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
Xavi
How is possible to not find this Template anymore?
