ā2024-10-23
10:13 PM
ā2024-10-29
08:53 PM
Ok the party is started to push perpetual licence to subscription. We don't have access to Library part maker anymore unless go to subscription. This is very unfair the only tool at the end will be line and circle š
ā2024-10-24 03:11 AM
I am not quite sure what you mean.
LPM is available as a download from the Graphisoft web site.
https://graphisoft.com/downloads/addons/lpm/int
As far as I know you don't need a subscription to download or use it.
ā2024-10-24 05:03 PM
Ok I found out why. Before went you activate your SSA licence everything was done but now you have to go to your licence information and do SSA Status Validation to activate it.
ā2024-10-25 01:53 AM
But if you have a perpetual license but you donāt have a valid SSA you wonāt be able to use the tool. it is a kind a subscription.
ā2024-10-25 03:24 AM
I have no issues downloading LPM for AC28. I do not even have an AC licence associated with my GSID and have not had one since 2017...
ā2024-10-29 08:55 PM
The LPM download page says:
"Please make sure that your Archicad License is an SSA license. (You may also use LPM with Trial or Educational licenses.)"
ā2025-02-10 07:11 PM
Hi Laszlo:
I have the SSA subscription (2 licenses in fact), and have installed the Archicad 27 where the LPM works, but I also use the A25 (in Mac or PC) but in both appears this message appears (it says the SSA is not renewed, but actually is)
ā
ā2025-02-10 08:31 PM - edited ā2025-02-10 08:31 PM
I recommend that you talk to your local reseller you purchased the license from and they will be able to sort it out.
ā2025-02-11 02:28 AM
I am not sure this will work.
Go to the HELP menu and check you are signed in with your Graphisoft ID
Then HELP > License Information.
Presse the SSA Status Validation button to see if that does anything.
If not then contact local support.
ā2025-02-11 08:06 AM
Ok thanks, I tried it, there was a validation ok, but didn't work for the LPM...
I'll be calling local support
