Library part maker ( need subscription)
mhoude
Ok the party is started to push perpetual licence to subscription. We don't have access to Library part maker anymore unless go to subscription. This is very unfair the only tool at the end will be line and circle šŸ˜ž
9 REPLIES 9
I am not quite sure what you mean.
LPM is available as a download from the Graphisoft web site.
https://graphisoft.com/downloads/addons/lpm/int
As far as I know you don't need a subscription to download or use it.
Ok I found out why. Before went you activate your SSA licence everything was done but now you have to go to your licence information and do SSA Status Validation to activate it.
But if you have a perpetual license but you don’t have a valid SSA you won’t be able to use the tool. it is a kind a subscription.
I have no issues downloading LPM for AC28. I do not even have an AC licence associated with my GSID and have not had one since 2017...
The LPM download page says:
"Please make sure that your Archicad License is an SSA license. (You may also use LPM with Trial or Educational licenses.)"
Hi Laszlo:
I have the SSA subscription (2 licenses in fact), and have installed the Archicad 27 where the LPM works, but I also use the A25 (in Mac or PC) but in both appears this message appears (it says the SSA is not renewed, but actually is)
ā€ƒ
I recommend that you talk to your local reseller you purchased the license from and they will be able to sort it out.
I am not sure this will work.
Go to the HELP menu and check you are signed in with your Graphisoft ID
Then HELP > License Information.
Presse the SSA Status Validation button to see if that does anything.
If not then contact local support.
Ok thanks, I tried it, there was a validation ok, but didn't work for the LPM...
I'll be calling local support
