GDL
Making parametric 2D objects with GDL
Reilly
I am currently working on creating a library of objects for my office. I have had success creating customizable 2D objects with certain parameters and options such as different views and elements that can be turned on and off (e.g. a sink with the option of showing/hiding the pedestal, or a bed with headboard and footboard that can be turned off). So far, though, I am limited to objects with fixed dimensions and want to create objects that can stretch and be more customizable. For example, I can create an object like a bed, which has a number of set standard sizes, and toggle between these sizes as options in the settings. However, I want to create an object like a couch which can be stretched to custom sizes without the arms being distorted.
Essentially, how can I make specific lines stretch without distorting other lines in a 2D object?
cuba
There are some great tutorials about this on barking dog bim:
https://www.youtube.com/@BarkingDogBIM/videos
Apple M1 Max 32 GB Ventura
AC27
I have been going through his tutorials but I haven't found a quick answer to this specific question yet. I'm sure it will come up but I figured it couldn't hurt to ask here in case someone has experience with this.
You need to learn how to script in GDL.
Use parameters for your various lengths, widths and heights.
Then instead of scripting a fixed size line (LINE2 0,0 3,0) you would use the parameters in the command.
i.e. this will give you an adjustable cabinet (box made of lines - you could also just use RECT2)
LINE2 0,0,cabinet_length,0
LINE2 cabinet_length,0,cabinet_length,cabinet_depth
LINE2 cabinet_length,cabinet_depth,0,cabinet_depth
LINE2 0,cabinet_depth,0,0
or
RECT2 0,0,cabinet_length,cabinet_depth
There is much more involved though.
Setup info provided by author
