2024-10-17 09:35 PM
I am currently working on creating a library of objects for my office. I have had success creating customizable 2D objects with certain parameters and options such as different views and elements that can be turned on and off (e.g. a sink with the option of showing/hiding the pedestal, or a bed with headboard and footboard that can be turned off). So far, though, I am limited to objects with fixed dimensions and want to create objects that can stretch and be more customizable. For example, I can create an object like a bed, which has a number of set standard sizes, and toggle between these sizes as options in the settings. However, I want to create an object like a couch which can be stretched to custom sizes without the arms being distorted.
Essentially, how can I make specific lines stretch without distorting other lines in a 2D object?
2024-10-17 10:14 PM
There are some great tutorials about this on barking dog bim:
https://www.youtube.com/@BarkingDogBIM/videos
a month ago
I have been going through his tutorials but I haven't found a quick answer to this specific question yet. I'm sure it will come up but I figured it couldn't hurt to ask here in case someone has experience with this.
a month ago
You need to learn how to script in GDL.
Use parameters for your various lengths, widths and heights.
Then instead of scripting a fixed size line (LINE2 0,0 3,0) you would use the parameters in the command.
i.e. this will give you an adjustable cabinet (box made of lines - you could also just use RECT2)
LINE2 0,0,cabinet_length,0
LINE2 cabinet_length,0,cabinet_length,cabinet_depth
LINE2 cabinet_length,cabinet_depth,0,cabinet_depth
LINE2 0,cabinet_depth,0,0
or
RECT2 0,0,cabinet_length,cabinet_depth
There is much more involved though.
