Migration 12 Library
dhnguyen
Hi All,
Could somebody please share with me your ArchiCAD Migration 12 Library?
(I'm missing a bunch of objects and don't know how to link them to the new library).
DNguyen
ArchiCAD 18- 25
(expert in AutoCAD, novice in ArchiCAD)
Eduardo Rolon
AC12 Migration should be inside your Application Folder->Graphisoft->Archicad 18-> ARCHICAD Migration Libraries
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
4 REPLIES 4
Eduardo Rolon
AC29 US/INT -> AC08
another Moderator
dhnguyen
I see, thank you!
DNguyen
ArchiCAD 18- 25
dhnguyen
Follow up question: Where Do I go to find ArchiCAD Library 15 and not the migration library 15?
DNguyen
ArchiCAD 18- 25
Eduardo Rolon
You will need to install 15 then.
AC29 US/INT -> AC08
another Moderator
