Modular Wardrobe bug
Hello
When I use a modular wardrobe, and in the "module plan" settings, the diferente dimensions I define, changes to the uniform dimensions after I close the settings and return to then
I have found he same issue on the modular wardrobe 16 from ArchiCAD library 16. Has it perhaps been fixed on the AC17 library? Anyone knows how to fix this bug?
Cheers?
The image in the original poster's post shows an AC17 object so I suppose the issue is not fixed in AC17.
Eduardo Rolon
Reported as bug though I don't know if it will be fixed in 17.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
