The library manager is just showing the library objects you have embedded into the MOD files.
You will probably need to open those MOD files separately and edit with the library manager there if you want to make changes to them.
As for the "Front" & "CAL room corner -rev" MODs (which don't appear in you hotlink list) - I am wondering if these are MODS linked from another MOD - i.e. a hotlink inside a hotlink.
So again you will have to open the parent MOD file to edit there.
