Move or copy Library from BIM server to embedded
I am working on a TW project, trying to set up a new "list scheme" by duplicating an existing scheme, in this case, "Component List Scheme > Basic".
I get the error message: "The files needed...are located in a BIM Server Library. Try moving these files into the Embedded Library."
I am unable to figure out how to move those files, any help appreciated.
In the Library manager Dialog of ArchiCAD, select the linked BIM Server Library and the "Embed placed objects of selected library" button will become enabled.
You will probably have to use that button to do this.
