New meshes and object wont appear in saved 3d views
Hello. Im building a simple site model, constructing the houses with the mesh tool. I've saved a 3D viewport with the settings that i want. But when I construct new meshes in plan view (using the same settings for the mesh), these new meshes wont appear in my saved 3D view.
Its very frustrating. Any ideas?
David Maudlin
orrepova:
One possibility is the Renovation Status of the new Meshes is different from the older ones, and the Renovation Filter is hiding them. Check their renovation Status. If you option-click an element to pick up its properties, it does not transfer the Renovation Status.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Thank you for your reply!
unfortunately It did not solve the problem. All meshes are existing.
If your 3D is a saved View, that View also contains information about what elements to display in 3D.
Maybe it does not include the Mesh you created in the Floor Plan Viewpoint.
Activate the saved 3D View, then right-click and select the "Show All in 3D" command. If this is the cause, it should display that Mesh you created.
You would then need to resave the View to include those elements as well.
