No conversion from string to numerical?
Hi guys,
Is it possible to convert a string variable to a numerical value in GDL?
I know it is possible to convert a numerical to a string, but what about the other way? I cannot seem to find any such command.
7 REPLIES 7
laszlonagy wrote:
Hi guys,
Hi Laszlo,
SPLIT function should do the trick.
string = "3 pieces 2x5 beam"
n = split (string, "%n pieces %nx%n %s", num, string1, size1, string2, size2, name)
print num, string1, size1, string2, size2, name
print vartype(num), vartype(string1), vartype(size1), vartype(string2), vartype(size2), vartype(name)
!!! 1 numeric, 2 string
Olivier
I would like to add, that if you call
SPLIT( "3.45", "%n", X)
it returns X=3.45!
Leo
Thanks guys,
I knew there must have been something.
I have not used this command for a very long time.
You are welcome, new horrible moderator !
What a pity I couldn't recommend you a function for converting strings (for example) to your daytime and stamina
Good luck,
Leo
Djordje
Ace
Give the guy a chance ... he is nowhere near horrible! 😉
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Yes Sir, THE MOST HORRIBLE MODERATOR OF THE FORUM WHO WE'VE EVER SEEN AND FOREVER ! We'll give him a chance
Thanks.
