2008-01-14 10:14 AM
2008-01-14 11:49 AM
2008-01-14 03:14 PM
Hunter wrote:Hunter:
Can anyone please tell me how I can link my home made north point to the project north, so that if I change the angle of the project north, the symbol updates to the same rotation too?
I am guessing that I'll need to add some parameters and code?
2008-01-14 05:04 PM
Hunter wrote:Just open the project north symbol delivered with archicad. The code is all there.
Tried a search for this, but with no luck.
I am guessing that I'll need to add some parameters and code?![]()
Thanks for any helpful replies.
Hunter.
2008-01-15 06:14 AM
2008-01-15 06:28 AM
2008-01-15 06:51 AM
2008-01-15 08:04 AM
2008-01-15 01:42 PM
Dwight wrote:When I made my part, I selected the elements (which were centered on the project origin) and selected save as library part. But it still rotates around the bottom left corner. I am not sure how else I can move it. If I just copy and paste the symbol into the 2D Symbol window, then I can't use the GDL code copied from the AC North Symbol.
I speculate that the code rotates around the origin of the object. Try to fix the problem by dragging your symbol's center down to the bottom corner from where it now rotates. It should then rotate correctly.......
2008-01-17 03:14 PM
