‎2009-11-02 07:33 PM
‎2009-11-02 08:00 PM
‎2009-11-03 09:39 AM
‎2009-11-03 07:49 PM
fill sectFillType
pen sectFillPen
project2{3} 3, 270, 3 + 32, 4, sectBkgdPen parameters showSection = 1
Then do a projection to show the uncut surfaces:
pen viewPen project2 3, 270, 2The clumsy part is that you would have to use a thin slice rather than a cutting plane to get your cut surfaces. In the 3D script, you would use group operations:
group "model"
(the code to create your model)
endgroup
if showSection then
group "cutter"
(transformation to adjust the height of the cutting 'plane' - actually a thin prism)
prism 4, .001,
-1000, -1000,
1000, -1000,
1000, 1000,
-1000, 1000
endgroup
result = isectgroup("model", "cutter")
placegroup result
else
placegroup "model"
endif
I would be interested to hear if anyone has a better way, as this is a bit of a hack.
‎2009-11-03 08:05 PM
‎2010-08-18 03:25 PM
