PM: What is the CODE to use in GDL for plotmaker labels?
tsturm
I know that this has been discussed in one of these forums before. I could not find it using the search tool. I hope that someone has already done this before an knows what to use.
I have a detail box and want to use the auto numbering feature of Plotmaker. What is the command to use in the GDL script to get this done?
I looked all over the place for a part to read the code from.
TIA.
Terrence Sturm, Architect
_______________
MBP OSX 10.15.4 Quad Core Intel i7 2.2hz
AC 17 build 5019
AC 22 build 7000
AC 23 build
AC 24 build 5000
4 REPLIES 4
This subject can get rather complex and there are some mind bending subtleties for certain functions, but the easy bit is...
You can include the PlotMaker auto-text as a string (plain text in quotes or in the value of a string type variable) in the same format as it is in PM.
<DRAWINGNAME> for example. (I don't know if it is case sensitive, but as I recall PM uses all caps.)
Aussie John
Matthew it appears it is
Cheers John
[/size]
Yes, it must be all CAPS.
Check out 'Use of AUTOTEXT entities in PlotMaker' at
http://www.graphisoft.com/support/archicad/archiguide/UseofAUTOTEXTinPM.html
Laszlo
tsturm
thanks Lazlo for the page link.
That was precisely what I was looking for.
thanks to GS for making the information available.
_______________
AC 17 build 5019
AC 22 build 7000
AC 23 build
AC 24 build 5000
