Presentation Setting for Object
Tuyen_DC
I can't change the setting of this object to publish correctly. It looks very bold at all when publishing. please help
Operating system used: Windows 14 23h2
8 REPLIES 8
Guru
The railing is not on a locked layer? If it is bugged, you could eyedropper it and redraw it. Your elevation line is not cutting through it?
How can I redraw it. I dont understand much word "Eyedropper". Could you please explain more?
Thanks
Guru
Press Alt and click on the railing. Your tool will swich to match that of the entity that you clicked on with matching settings.
https://help.graphisoft.com/AC/28/INT/_AC28_Help/030_Interaction/030_Interaction-98.htm
The SOE of the GS help pages and articles is horrendous...
this object is from archicad library. My balustrade is from Customer Library so cannot match the setting. Any other solution sir 😞 ?
So the railing on the balcony is a different object to the railing on the stair?
Is there a reason why you can't use the same object for both?
If the stair railing is a different object, you will just have to look at all of the settings in that object.
Yes, we dont have 45 angle railing so use from AC library. I have looked the setting but dont know why hic
Guru
So you are using pre-AC21? You should include some information about your AC version and computer setup in your signature, see link in my signature, or at least use the forums AC version input when creating a thread.
Also, if you are asking questions regarding a 3rd party library, it would be helpful to mention which library it is in your OP.
Ling.
Pato99
The new rails do go on angle if you're placing in 3D.
If it's a custom object, can you open the object CTRL+SHIFT+O and change the Pen Parameters.
Make sure you know what you're doing though because you can break the object if you mess around with parameters. But changing pen numbers will be fine.
Alternatively create a new pen set for that elevation layout and whatever pen is being used (6-7) on the object, change the pen weight to 0.10 thickness.
Versions 10 to forced subscription
Please vote for Constant thickness to mesh What will GS do when they reach 200 votes? Less than 30 votes to go!
Please also vote for my whishes, as 200 votes in 6 months is an impossible target, don't be a bystander:
1. Relative file locations | 2. Auto text in Publishing | 3. Model types to Grasshopper | 4. Index Numbers in Search | 5. Step through Elevations | 6. Rhino is better than ArchiCAD
Here's a reminder of what you're voting for: Wishes Delivered
Setup info provided by author
