‎2024-10-10
02:51 AM
‎2024-10-12
06:34 AM
I can't change the setting of this object to publish correctly. It looks very bold at all when publishing. please help
Operating system used: Windows 14 23h2
‎2024-10-10 03:49 AM
The railing is not on a locked layer? If it is bugged, you could eyedropper it and redraw it. Your elevation line is not cutting through it?
‎2024-10-10 03:52 AM
How can I redraw it. I dont understand much word "Eyedropper". Could you please explain more?
Thanks
‎2024-10-10 03:57 AM - edited ‎2024-10-10 04:00 AM
Press Alt and click on the railing. Your tool will swich to match that of the entity that you clicked on with matching settings.
https://help.graphisoft.com/AC/28/INT/_AC28_Help/030_Interaction/030_Interaction-98.htm
The SOE of the GS help pages and articles is horrendous...
‎2024-10-10 04:03 AM
this object is from archicad library. My balustrade is from Customer Library so cannot match the setting. Any other solution sir 😞 ?
‎2024-10-10 04:13 AM
So the railing on the balcony is a different object to the railing on the stair?
Is there a reason why you can't use the same object for both?
If the stair railing is a different object, you will just have to look at all of the settings in that object.
‎2024-10-10 04:15 AM
Yes, we dont have 45 angle railing so use from AC library. I have looked the setting but dont know why hic
‎2024-10-10 04:57 AM - edited ‎2024-10-10 04:58 AM
So you are using pre-AC21? You should include some information about your AC version and computer setup in your signature, see link in my signature, or at least use the forums AC version input when creating a thread.
Also, if you are asking questions regarding a 3rd party library, it would be helpful to mention which library it is in your OP.
Ling.
‎2024-10-10 05:09 AM
The new rails do go on angle if you're placing in 3D.
If it's a custom object, can you open the object CTRL+SHIFT+O and change the Pen Parameters.
Make sure you know what you're doing though because you can break the object if you mess around with parameters. But changing pen numbers will be fine.
Alternatively create a new pen set for that elevation layout and whatever pen is being used (6-7) on the object, change the pen weight to 0.10 thickness.
