Run out of parameters - help, please
I have run out of available parameters.
In an effort to get round this GDL limitation I have tried using a parameter as a simple array, with four possble values, thereby using one parameter instaed of four!!
My problem is that these values are, ideally, boolean (checkboxes), and I cannot get them to appear via the Interface script, no matter what I do. I don't need any associated pictures in the interface, and the checkboxes are 'independent' inasmuchas none affects another, and the result I want is not appropriate for drop-down boxes etc. I also want to avoid the need for the user to have to enter a value, if at all possible.
I understand the process (I think):
UI_INFIELD "checkbox[1]" 100,100,14,14
UI_INFIELD "checkbox[2]" 100,116,14,14
... and so on.
I've tried a loop, thus:
FOR j = 1 TO 4
param="checkbox["+Str(j,1,0)+"]"
UI_INFIELD param 100,84+j*16,14,14
NEXT j
Neither works.
Am I on a Fool's Errand, or does someone really knowledgeable and helpful know how to overcome this little difficulty?
BTW: it is not possible for me to re-engineer the object - I didn't originate the scripts, and I don't have full acces to all the associated Macros.
4 REPLIES 4
Frank Beister
Does
work? I have no manual by the hand (tomorrow in the office) to proof, but AFAIR you have to use the new infield-command UI_INFIELD{2}.
UI_INFIELD "checkbox[1]" 100,100,14,14 doesn't work, but if I use
UI_INFIELD{2} "checkbox[1]" 100,100,14,14 I get an error indicating that there is a parameter missing, or some such!!
Can you advise by giving a simple example of how to get this new command to work? The example in the ArchiCAD GDL Help doen't give working examples of this command!
AHA! GOT IT!
The new UN_INFIELD{2} doesn't require parentheses around the parameter name!
Obvious when you think about it(??)
My thanks go to F Beister, who made me THINK about what I was doing!!
MikeS wrote:
AHA! GOT IT!
One of the great benefits of this (apart from being able to use arrays) is that you can build Spreadsheet style interfaces in the UI - I am even thinking of making a SuDoku puzzle solver with this GDL command.
