STAIR TOOL and line weight- I Surrender!
Does anyone know why the AC 10 stair tool insists on plotting out at a heavy lineweight? I have changed EVERY line weight setting in the tool settings window and in the Stair editor and it seems to be of no avail.
What am I missing, here?
Thanks,
Stephen
7 REPLIES 7
__archiben
Floor Plan and Section>Enable Object's Pens check box?
~/archiben
b e n f r o s t
Djordje
Ace
StairMaker stair?
Did you set the pens when creating the stair in the StairMaker dialogs?
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
UNchecking the use objects pens did the trick. Still don't know why I can't get to whatever pen it's using, however.
~/archiben
2raarchitecture
I am having the same problem, and I checked and unchecked the Enable Objects pens to no avail.
2RA Building Workshop
www.2rabldgworkshop.com
11th Gen Intel(R) Core(TM) i7-11800H @ 2.30GHz. 16.0 GB. NVIDIA GeForce RTX 3060 Laptop GPU.
ArchiCAD 25. 5002 USA Full
2raarchitecture,
You answered a 15-year old thread. The Stair tool did not exist at that time (what existed at that time was another tool called StairMaker).
Can you give more detail (possibly with screenshots) about the issue you are facing?
Thank you kindly for your reply. It's not helpful to tell people how old a post is. The solution was to change the model view options for both railings and stairs to full instead of simplified. Please, see attached.
Thanks for the solution, hopefully, others will find it useful.
By the way, there is no attachment in your last post.
