Script Length
I have created a couple of super window parts and the script that corresponds to the part is quite lengthy. I have put all the window sizes and grilles, colors etc. in the script. The script checks out OK but when I use the part it doesn't always work. I have tried breaking it up into sub routines, but it still has problems. I guess my question is: Does the length of the script affect how a part works? Or where in a script a statement is made? Thanks.
Barry Halloran
7 REPLIES 7
I know you can't have more than 8 variables in an if statement. I had to cut some of mine in half. No doubt there are other maximums.
Frank Beister
I have written some objects with about 2.500 lines total and >500kB without implemented picts. And they work fine. I don't think there's a reachable limit of script length.
@Barry:
if a<5 and b<7 and c=0 and d=0 and e<15 and f>-2 and g>-8 and h>-15 and i<25 then print "it works"
works fine. I don't know about limitations in the if .. then statement.
Frank Beister
There are limitations in the length of lines. It's about 240 characters max. Maybe this is a problem.
I confirm. No limits for "if ... then" statements.
Max length line is 255 characters, including spaces.
GS recommends max 120 for lines, and 31 for file names.
The number of parameters is limited to 512.
Frank Beister
AC 8.x+ 512 parameters
AC 7 128 parameters (AFAIR)
AC 6.x 64 parameters (AFAIR)
This are the silent improvements in GDL. I have had some trouble with a few objects in AC 6, because I needed more than 64 parameters. But there was a trick to use Arrays as storage and a couple of multiple used normal parameters to push the values by an user interface and the parameter script into the arrays.
Workarounds, always workarounds.
With the time, we have learned how to become Masters in workarounds.
I must admit i didn't try to test this limit.
Frank Beister
... and how to make impossible things work. 😉
