Sharing custom surfaces across projects
Hello
What is the most efficient way of making custom made surfaces available across different projects?
I know you can save a file from attributes manager and load into another project, but I was wondering if there is now a way to save custom made surfaces or complex profiles to a centralized database that is immediately accessible to other projects.
Is this feature available in Teamwork? Do people working alone use Teamwork to centralize libraries and to make customized attributes available to all their other projects?
Thanks
Attribute Manager is the only means of moving any attributes - such as surfaces - from one file to another. In TW, of course, the user adding the attributes must have access rights and a reservation to modify things.
AC 29 USA and earlier   ā€¢   hardware key   ā€¢   macOS Taho 26.1 MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
Thanks Karl, that is what I feared.
Hopefully AC will one day have an attributes manager that can synchronize to a centralized office attributes file folder. Cant be that difficult to do can it?
You wouldn't think so, but it has been on the wish list for a long time... so who knows when we'll see it... We could still have 'embedded' attributes like now to freeze things... but live-linked attributes (and other settings - such as CineRender scenes) would sure simplify complex projects.
