Sill to wall base height discrepancy
I'm experiencing a discrepancy in a project I'm working on:
Sill to wall base height is set to 900 mm. In my plan, however, the window label says 599 mm. Can anyone explain this, and what to do about it?
See attached screen shot.
I appreciate any help.
Truls
Daniel Kovacs
I think this could go sideways at several places:
- Make sure that the marker is set to measure the height from the wall base, and not the story or the Anchor
- There's a Sub-floor thickness value under the "Dimension Marker" tab, that is usually 100 mm by default. This value is subtracted from the measured value, so make sure this is set to 0.
Other than that, it should be fine.
Regards,
Daniel Alexander Kovacs
GRAPHISOFT
Thanks so much for your answer, dkovacs!
(I thought I was automatically emailed when a reply was posted, so I eventually found a usable solution myself, and did not check in here until now:)
Regards,
Truls
Guru
Check your notification settings in the user control panel.
Ling.
